Thanks to the forum, I recently got a '56 Golden Hawk dash to put in my '54 Commander coupe. As part of changing the dash, I will convert the car to 12 volts. I have collected up virtually all the parts I will need for the conversion. But one remaining question, is what to do about the fuel tank sender. It will need to work with my '56 12v fuel gauge AND my '54 fuel tank. Studebaker International has "1549575, fuel sending unit, 1958-66 car." This would be a 12v sender, but will it attach to my '54 fuel tank?
Converting '54 coupe with '56 dash to 12v -- what fuel sender to use?
Electrical: Converting '54 coupe with '56 dash to 12v -- what fuel sender to use?
Pete R
Woodbridge, VA
1954 Studebaker Commander Regal Starlight Coupe with '62 289 and 4-speed
1964 Studebaker Avanti R5083 R2 4-speed with 4.09:1 Twin Traction -
1549575 is what I have in my 61 hawk which is the same tank as your 54 I believe
I would ask the vendor you buy this from that question as if it does not work then you could return itMilt
1961 Hawk 4-speed
1967 Avanti
1961 Lark 2 door
1988 Avanti Convertible
Member of SDC since 1973
According to the parts manuals, the '54 tank and the '61 tank have different part numbers. But I also noticed that the same sending unit gasket was used from at least '51 through '58. And 1549575 fits '58-66. So it seems that the bolt pattern of 1549575 is the same as on my tank. I guess it will fit.Pete R
Woodbridge, VA
I believe the bolt patterns (and gaskets) are pretty much standard for most cars of the era so don't use that as a guide for application of the sending unit. Depth of the tank would be the most important dimension. You can always use a 12 volt universal unit with an adjustable float arm.
Originally posted by Pete R View PostAccording to the parts manuals, the '54 tank and the '61 tank have different part numbers.
My 56 wagon had the fuel pickup tube run through the fuel sender, while most of the other tanks I've ever seen use a fuel pickup tube separate from the sender. THis may be the issue at hand. Does the 56 tank even have a pickup tube in the bottom of the tank?sals54
If someone needs a fuel sender with the pickup tube passing through it, any of the standard senders can be modified by drilling a hole in the appropriate location, bending up piece of 5/16" (or 3/8") steel fuel line, and soldering it in position.
Originally posted by SN-60 View PostIf someone needs a fuel sender with the pickup tube passing through it, any of the standard senders can be modified by drilling a hole in the appropriate location, bending up piece of 5/16" (or 3/8") steel fuel line, and soldering it in position.Bez Auto Alchemy
Originally posted by sals54 View PostMy 56 wagon had the fuel pickup tube run through the fuel sender, while most of the other tanks I've ever seen use a fuel pickup tube separate from the sender. THis may be the issue at hand. Does the 56 tank even have a pickup tube in the bottom of the tank?
