I removed one of the heads (for another reason) and discovered the #8 cylinder was 1/2 full of coolant. To my knowledge, the only way this could happen is from a blown head gasket. The engine was recently rebuilt and the gasket was brand new. Also, inspecting the head and the block with a magnifying glass revealed no cracks in either. Also, there was no obvious visible 'trail' on the gasket itself to indicate the pathway. However, I replaced the gasket with a new one and put it all back together. Like I said, the engine was recently overhauled but I had done some cranking of the engine before removing the head.
Now I am wondering if maybe the coolant got into the cylinder some other way? One other possibility of course would be if I did not torque the head bolts correctly but when I removed them, they were all equally tight and I was very careful to follow the correct torquing sequence when I put it together. None of the other cylinders had coolant and the oil is not cloudy at all - apparently the new rings did a good job and held the fluid in the cylinder.
If there was some other reason this happened, pls let me know. Also, I am not planning to remove the other head unless someone has a reason to do that. Thanks for any help.
