Lark rubber
  • Lark rubber
    Looking for input on weatherstripping and trunk seals for my 59 Lark. Is factory stuff still available? Is it any good? Any good aftermarket sources? Thanks guys
    Been wondering the same for my 59... Found a few pieces through SI but not everything.
      The '59/'60 Lark 4 door Kit contains 20 Part Numbers, 141 Pieces, that outta do it!
        My lark is a two door sedan . Im a newbie to studes ,do you think the four door weatherstripping will fit the longer front doors?
          The 4 door rubber is to short, You'd have to ad to it for the 2 door.
          Joseph R. Zeiger
            Have you tried Valerie Hanson at Studebaker Rubber Gaskets yet? She probably has it all. http://studebakervendors.com/hansen/index.htm
            Mike Davis
            1964 Champ 8E7-122 "Stuey"
              No, you don't use the 4 Door Kit on a 2 Door, about Half of it would be wrong, you order the 2 Door Sedan Kit, it is $174.60 Less.
                Found it... Page 95 in Studebaker international catalog should have everything you need Lumpy...
                  Thanks for the input everyone Will call monday.
