Anyone have one for sale?
4 Speed Starter
That one appears to be a Delco, used before most of the 4 Speeds came out, that were Prestolite/Autolite.
Could that be from a '61 4 Speed?StudeRich
Originally posted by StudeRich View PostThat one appears to be a Delco, used before most of the 4 Speeds came out, that were Prestolite/Autolite.
Could that be from a '61 4 Speed?Jack White
Charlotte,NC
North Carolina Studebaker Drivers Club
It shouldn't matter whether it's a 4 speed or 3 speed starter. If you have a '63 set-up in the vehicle it should be a Prestolite 7025. The automatics used a 7026. Really the only difference externally is the housing going into the bellhousing which could be swapped.
Rob in PA.
I've been trying to find the right starter, or starter "nose", for an Avanti. I am converting to a 5 speed from A/t. I am at a loss to understand why there are any differences in any manual transmission starters. The flywheel ring is in the same place, the block to gear distance is exactly the same, the gear is the same, the centering of the starter bolts to motor shaft is the same. The only difference I can think of would be the "depression" in one bell housing verses another where the "nose" has to clear the bell housing to fit. The starter doesn't care if it's a 3,4,5 or 6 speed bolted to the bell housing. Other than the motors torque to spin I can't see why there would be any difference. The bendix drive has to travel the same distance to clear or engage the teeth completely to be and work right. All the different noses just move the whole motor in or out from the face of the bell housing to accommodate the motors shaft length. Why so many problems, using the "wrong" one??
I have a starter nose that's 2 1/8 long from a 4 speed parts car. Mice made a huge nest/bathroom inside the bell housing so the starter drive is rusty. I never tried to take it a part but I'll try if you want the nose piece.
Ken
Originally posted by altair View PostI bought a 259 minus the transmission, that was a 4 speed and replaced it with a 3 speed with overdrive and the starter was the same. The 3 speed or 4 speed had no effect on the starter.
This website is for sale! raylinrestoration.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, raylinrestoration.com has it all. We hope you find what you are searching for!
Robert Kapteyn
I don't get the confision
There is only one part number - 1550502 for all 62, 63, and 64 V8 with manual transmission. Perhaps we are trying to mix other years?? Avantis do have different part numbers because they have an additional field coil for the higher compression78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
55 Speedster 7160047
55 Speedster 7165279
