So, I have a 60 Lark VI wagon and I found I have a rear drum with one snapped stud and at least one stripped stud as well.
How do you remove stripped studs where the nut and stud spin? I'll have to look, there MAY be enough thread on the end to install another lug nut, but I'm not sure if there are enough threads on the outside of the stripped lug nut. At least, they're older traditional lug nuts, and not the newer replacement shouldered nuts I have on other rims where the thread are recessed from the nut shoulder.
As it stands now, I may not have access to 3 lug nut studs in order to use my drum puller.
