I am getting water coming in past the door seals at the front top of the doors on my 62 GT. Here are pics of the door seals and if you'll notice the driver's side is much higher up than the passenger side. The driver's side leaks worse but both sides do leak. The main door seals are fairly new, not cracked and look to be in the right place.
Do these seals look to be correct and in the right place? The water runs in the front and down the wind lace to the carpet at the bottom of the door post. Anyone had similar problems? Suggestions?
