trying to find a seat for my 3r6,seems to be different, just bought a scottsman but it has the brackets on the back of the cab my 54 does not,so not sure what to do,
Seats
Your 3R6 probably came with the adjustable seat that allowed a small amount of fore-and-aft movement by pulling up on lever on the side of the seat. The Scotsman trucks used the cheaper arrangement with a hole-and-pin arrangement. I have an extra seat frame and cushions, but shipping would be prohibitive. You should be able to find one a lot closer. Suggest you post a want-to-buy ad over on Stude Truck Talk. There are several people who post there that specialize in used Stude truck parts.
Skip Lackie
thank you skip , I did end up with what looks like someone put a slider frame in the scottsman with the pin type back cushion and bottom,can you tell me what I have, the ser. # E1-766 Mod. #3E1-12. it has been wrecked there is 54 front clip on it and the frame in front has a couple inches cut off, any info. would be helpful it only shows 58k on the speed-o ,6 cyl. 3 speed o.d. thanks Dino
Originally posted by jetboat View Postthank you skip , I did end up with what looks like someone put a slider frame in the scottsman with the pin type back cushion and bottom,can you tell me what I have, the ser. # E1-766 Mod. #3E1-12. it has been wrecked there is 54 front clip on it and the frame in front has a couple inches cut off, any info. would be helpful it only shows 58k on the speed-o ,6 cyl. 3 speed o.d. thanks DinoSkip Lackie
