Any One using Dog Dish Caps other than Originals on a 1/2 Ton Champ. if so, what Make are They? maybe some Pics if any.
60 - 64 Champ " Brand X " Hub Caps ?
Would ANY other make have a fastener pattern wheel that matches the special Studebaker only Spring Clip pattern?
If there were an old Kaiser, Willys or International that matches, I am thinking those would be MUCH harder to find than the correct ones which ARE available.StudeRich
Have You actually tried doing what You think I'm trying to do - NO! You have any idea what size Cap was used on say a mid 80s S-10 2WD Truck,or GMC Safari Van ? "likely not". I don't know off Hand My self,even though I once owned said S-10 .............. that's the purpose of this post,maybe others have ventured outside the BOX. I have a Champ,and am well aware of SIs repop Caps thanks !
Originally posted by StudeRich View PostWould ANY other make have a fastener pattern wheel that matches the special Studebaker only Spring Clip pattern?
If there were an old Kaiser, Willys or International that matches, I am thinking those would be MUCH harder to find than the correct ones which ARE available.Joseph R. Zeiger
Joseph, no one but me knows what I know, certainly not you. So please do not try to second guess peoples' knowledge or lack of it.
Do I have to remind you that; personal attack Posts are not allowed here.StudeRich
Richard, in no way shape or form is it a Personal attack "You should give that chronic plea a rest already"! and now that You initially got this Thread off Topic,hopefully Some One will come fourth with what I asked for.Joseph R. Zeiger
When I wanna find out such stuff I google for example "Dodge dogdisk diameter" or such.
But I've always had trouble the other way around, that Studebaker caps don't fit on other rims, but if some other brand caps comes close than I'm thinking it might be possible to bend the springy bits a bit... maby?
I'll throw out the wacky suggestion of checking out horse and stock trailer hubcaps.1963 Champ "Stu Bludebaker"- sometimes driver
1957 Silver Hawk "Josie"- picking up the pieces after an unreliable body man let it rot for 11 years from an almost driver to a basket case
1951 Land Cruiser "Bunnie Ketcher" only 47M miles!
1951 Commander Starlight "Dale"- basket case
1947 Champion "Sally"- basket case
1941 Commander Land Cruiser "Ursula"- basket case
Yep, I think you have a much better chance trying RV, Car Haulers, U-Haul, Horse, Utility etc. Trailers just like old Orphan Cars like: Nash, Hudson, Packard, Willys, Kaiser, International etc. than you do the Big Three Cars.StudeRich
I had another wacky idea on the way home from Runza: how about poverty hub caps from later '60s through earlier '80s 3/4 ton pickups? Although it wouldn't surprise me if these were a little too big.Last edited by DougHolverson; 08-10-2016, 07:17 AM.1963 Champ "Stu Bludebaker"- sometimes driver
There's always the VW hubcap clips that were riveted to the wheels. They can be attached to any wheel at any point so that Stude caps can be used on other wheels and vice versa. Some wheels may need the original hubcap "bumps" ground down or off to clear. Where there's a will, there's a way.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
Originally posted by thunderations View PostThere's always the VW hubcap clips that were riveted to the wheels. They can be attached to any wheel at any point so that Stude caps can be used on other wheels and vice versa. Some wheels may need the original hubcap "bumps" ground down or off to clear. Where there's a will, there's a way.
youtube has videos showing how to lay out and install clips on steel wheels.South Lompoc Studebaker
