master cylinder
  • Brakes: master cylinder
    What is the accepted thought(s) as to high to fill a dual mc?..........in today heat I found fluid had weeped over the sides of the cover and killed the nice paint job I did on the master.
    Can I run a m/c with half to 3/4 full?
    Thanks in advance for your thoughts:-)
    3/4 full would be good in my opinion but I would also inspect the level at shorter periods.
    60 Lark convertible V-8 auto
    61 Champ 1/2 ton 4 speed
    62 Champ 3/4 ton auto
    63 G.T. Hawk R-2,4 speed
    63 Avanti (2) R-1 auto
    64 Zip Van
    66 Cruiser V-8 auto
      You MAY possibly need a better Gasket than the cheap Chinese one supplied with most offshore Mfg. Replacement components.
      Also a switch to DOT 5 Silicone Fluid would also solve that and many more issues with Hydroscopic DOT 3 & 4 Fluids.
