What do you guys use to install the pulley hub to the crankshaft? How tight is the fit? 289 Stude motor.-Jim
Crank Pulley Install
Yep, a damper installer. You need to verify that the particular tool you buy has the correct threaded insert for the crankshaft. Some do...some don't.
Like mine...it didn't have the correct insert, I had to make my own. I used a diesel truck wheel stud. The machine shop that modified it hated it...too hard..! But they got it done.
Some 1 1/2" -2" Dia. spacers, a huge flat washer and the Crank Bolt, a longer one for Power Steering Cars works best, and just "Push" it on there, they are not all that hard of a interference fit.StudeRich
The 537522 is 3" the 515111 is 2 1/16" from Pg.169 S.I. Catalog, if you look them up in the Studebaker Chassis Parts Catalog you can tell which fits what model, year and equipment.
I am pretty sure those are the longer ones.StudeRich
Chuck Collins has one that sells for $59.00 Check out the bottom of this page. https://www.studebakerparts.com/stud...age=tools.html59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
