So I just want a couple of sheets to cover over were the climatizer is ,,, where do suggest I asked for , the companies? Or a speed shop , Maybe you ? Why , Because the climatizer is not hooked up since I bought it, and I have a Dealer installed heater under the dash that does work ( crudely) , and I am about to put down some new carpet , and just thought I could keep the road noise out, and possible exhaust gases, and the next guy can take it off if he wants too.... Thanks for the ideas,,, Mike 14x7
Dyna mat or or sum other sticky insulation
Bez Auto Alchemy
I was informed that asphalt base materials, like peel and seal, was a no no, it can burn. Butyl based rubberized compounds are what is in materials for automotive use. It is harder to find at hardware stores but there are some products out there. I have yet to find a good source for them. People have used the asphalt base materials with success but the risk is still there if there is excessive heat or fire.
This is a safer product but I have not used it so can't say for sure how well it works.
The trick is to find a butyl based material with a reflective aluminum outer side. The one above has a white side. Automotive products are made for sound deadening and as a heat barrier.
Len
P.S. This other stuff is better as it can be had in AF-15 2 mils aluminum foil, 15 mils butyl adhesive/sealant
• AF-25 2 mils aluminum foil, 25 mils butyl adhesive / sealant
Leading manufacturer of standard & custom engineered pads, tapes & gaskets for a wide range of industrial & OEM applications. Discover H - O Products.
Before shipping it costs about $1.23 a square foot, which is a bargain but again I have not used it so can't say about how effective it is. The main issue is you have to but a minimum of 5 rolls to get that price from that vendor.Last edited by Guest; 05-05-2016, 05:03 AM.
What Skybolt said.
Plus...that stuff noted above (bezhawk) is "NOT" the same as Dynamat.
What Skybolt is showing IS more like Dynamat. That add doesn't show how thick it is. Dynamat comes in a couple of different thicknesses and sizes.
Or...checkout what Summit of Jegs has to offer. They have more than just the Dynamat brand.
I used the eastwood product and dynamite. The eastwood stuff is not good for vertical surfaces such as the firewall. You also need to plug any holes that the eastwood product is going to cover. The rubber backing will ooze down vertical surfaces and out any hole that is under the product.
Dynamat is a much better product. It can go on vertical surfaces without the rubber oozing out over time.
I put eastwood on my firewall to start with. This is where I discovered that the rubber backing would ooze down a vertical surface over time. I ended up putting eastwood on the floor after I put silver tape over all the little holes. I put dynamite on the remaining vertical surfaces without any more problems.Wayne
"Trying to shed my CASO ways"
sigpic​
If your car is getting hot enough to ignite peel and seal, you've got far bigger problems than what kind of insulation you're using.
I've been using peel n seal for years on many different cars in many different applications. I've even used it to re-do an entire roof on an RV. It's some amazing stuff in the right application.
It's about 80% as effective as dynamat, but about 1/4 the cost. Some folks have complained of an asphalt or tar smell, but I've never experienced it. I wouldn't use it on overhead surfaces (roof, trunk lid, etc) and vertical surfaces need to be good and clean or it can 'slide' if it gets really hot, like SW USA desert hot.-------------------
Daddy always said, if yer gonna be dumb, you gotta be tough & I\'m one tough sumbiatch!
I used FatMat, same as Dynamat, but a lot less expensive.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
I have also used Peel and seal for years. I live right in the heat of it Phx az and never experienced any of the problems you guys are describing. I have an on my firewall on the out side I have it on my roof. I've been to Sacramento South Bend Denver California California California. And never experienced dripping sliding slipping or anything else you can think of for the money hands-down it's the best . And I drive my car it has never seen a trailer . Oh and that's with the Family on board. Have fun promoting that overpriced stuff.
Originally posted by Flat Ernie View PostIf your car is getting hot enough to ignite peel and seal, you've got far bigger problems than what kind of insulation you're using.
.Charles
1961 Lark Regal VIII 259/auto -- Lucy
