Hey, I've got a T10 four speed from a '62 Hawk and I need a few internal parts. Can anybody recommend a parts source? A business that & understands & sells parts for older transmissions- thanks- Jim
Need transmission parts source
I have heard there is a place called Border's in California that has lots of the old stuff including Studebaker transmission parts. Also, Studebaker International has quite a bit. I've been told that if you need an input shaft your best bet is SI."Madness...is the exception in individuals, but the rule in groups" - Nietzsche.
Originally posted by HawkBuilder View PostHey, I've got a T10 four speed from a '62 Hawk and I need a few internal parts. Can anybody recommend a parts source? A business that & understands & sells parts for older transmissions- thanks- Jim
jack vinesPackardV8
Your best bet is to get a parts book and tell us which parts you need and the part number. Vendors inventory their parts by part number.
I probably have what you need.
Robert Kapteyn
studebaker@mac.com
Here are a couple of other resources that I have used.
http://www.nwtparts.com/
Ed Sallia
Dundee, OR
Sol Lucet Omnibus
There is also Richmond Gear. They bought out the T-10 from Borg-Warner and still make the 4-Speed transmission. Short of the input shaft, I would think they'd have everything else...
Tom - Bradenton, FL
Originally posted by Commander Eddie View PostHere are a couple of other resources that I have used.
55 President Deluxe
64 Commander
66 Cruiser
37 Oldsmobile F37 4 Door
I just finished up my 1962 T-10 for my Lark, all new gears 1-4 I was able to reuse my cluster gear
my input shaft (4th) came from Jon Meyer everything else is reproduction GM gears made in Italy that came from WWW.thegearbox.org I found they had the best prices.
there are 2 ratios in 62 close and wide the 2 ratios used were also used in Chevrolet so we are very lucky in that regard since the vintage "vette" crowd gave enough of a demand that all new quality internals are available.Last edited by Pop's Chariot; 05-04-2016, 05:09 AM."Fords are cars Studebakers are Automobiles" -Jerry Washburn
Don't know what you need but this seems like a good source: http://www.drivetrainpartslasvegas.c...ory_s/2083.htm
