I'm rewiring my 1955 C3. The instrument light switch has 5 terminals. The wiring diagram shows only two wires going to the switch. Can this be? Five terminals and only two terminals used?
Instrument light switch
I just looked at an NOS 536218 instrument light switch and it has 5 plug in style terminals, so it sounds like you have the correct switch. I can't answer why there are five.Dan Peterson
Montpelier, VT
1960 Lark V-8 Convertible
This may be a little far out, but it might have been for export. On the early Euorpean roads it was required that you had to have the inside tail lights only on when parked on some of the narrow roads. I had owned an early Mercedes that had a four position dash light switch, on, off, left rear and right rear. FWIW
The reason the main Wiring Harness Diagram only shows the Power coming in from the Headlight Switch and the Dimmed or not, power going out to the Instruments is that some of the equipment was an Option, the Cigar Lighter Light and other options.
Did you test them all to find out if some are always Hot?
If they are not Dimmer controlled, but Hot when the Headlight Switch is on they could feed more options that could not be accommodated by the Headlight Switch, like Underhood Light, Trunk Light, Glove Box Light etc.StudeRich
