This is perhaps a bit off the Wall. is Any One aware of a Donut Spare that #1 has the same bolt pattern of a Champ 1/2 Ton Truck,and #2 of course an outer diameter that's fairly close ? I'm just not sure if any newer Trucks / Truck like SUVs even use these,but would be curious too know.
A Studebaker with a "Donut Spare Tire" under it
Joe
What is the bolt pattern you need and OD of the tire. Some of the newer pickups carry a spare that is essentially a full size thin walled spare not a normal deep treaded tire. My 14 Ram has one so I'll bet they are somewhat common. They come inflated not collapsed and needing inflation prior to use if that's what you need. Bob
Thanks Bob,just for the heck of it I may look at some of these.
Originally posted by sweetolbob View PostJoe
What is the bolt pattern you need and OD of the tire. Some of the newer pickups carry a spare that is essentially a full size thin walled spare not a normal deep treaded tire. My 14 Ram has one so I'll bet they are somewhat common. They come inflated not collapsed and needing inflation prior to use if that's what you need. BobJoseph R. Zeiger
