I have a '61 Hawk with a supercharged 289 - R2 style supercharger and carb, though a '61 build other than that, plus Pertronix ignition. When coming to a stop, the idle stays quite high unless I gun the engine, maybe even two or three times. The accelerator/carb linkages look fine; the idle screw sets solidly against its rest, the choke works properly, and the fast idle cam is all the way off when warm, so I'm pretty sure it's not that.
I'm thinking it might be the distributor. For one thing, the advance timing is quite high - like 20 degrees, even when at the lowest idle, around 700 RPMs. No knocking or pinging when going up hills or anything though, so I guess it can take it? I tried lowering it but when it got to around 5-8 degrees, the engine would sputter and die, even if I raised the idle screw, or it would backfire if revved. The total timing is around 50 degrees. That seems like a lot, too.
The vacuum advance is getting 7 pounds of pressure at idle coming from the carb, and up to about 20 at speed. I'm not sure if that sounds right or not, and if a sealed carb makes any difference in vacuum advance setup or not? If that IS okay, then I'm looking at the distributor mechanical advance being out of whack. I haven't yet opened up the distrib to have a look, but wanted to see what any of you think, if I'm heading in the right direction here or any other thoughts before digging deeper.
And if a distrib recurve is called for, does anyone know anybody in the Pacific Northwest who does that?
Any thoughts on this stuff would be much appreciated!
Dave
Dave
