Even though I have not been on here much, things are progressing. Thanks to the help of C&B, Studebakers West and Pops Chariot the car is sort of working as a car. If you remember I picked it up in Portland about a year ago.
Car now has a heater, the oil leaks are at least under control, wiring harness somewhat cleaned up and many grommets replaced. New bushings in the suspension (front and rear), repaired the dana 27 which had a spun hub (put the keys back! Thanks, previous owner). The transmission has been rebuilt as well. The front bearing was missing a bunch of rollers but I went through the whole thing. New trunk seal, liner and divider is also happening. I modified the brakes by changing the master cylinder to a Chevrolet unit with two circuits and a 1" bore. Stopping power has been greatly improved. The six with OD scoots the car along just fine
