David,
Have you had a chance to locate the drawing you have for the water manifold? I need to get my aluminum manifold fixed soon. I also plan on making one large aluminum plate straddling all eight mounting holes. Using studs, spacers and brackets the aluminum plate will support the alternator, power steering pump and vacuum pump. An accurate drawing will go a long way to getting it right the first time.
Regards,
Jon Kammer
Regards,
Jon Kammer
