Now that I've drug my '53 Coupe out, I'm remembering little things that bugged me before.
If the car sits for more than a couple of days, it's like the gas has all evaporated and drained back into the tank. I have to crank and crank and crank, and lately, it's easier to just stuff an air hose down the fuel filler to force prime it. If it ran yesterday, it cranks right up, but after two or three days, it's painful.
I've got an Edelbrock 1403 on a 289 with a stock Carter fuel pump. Not sure if it's a bad check valve in the pump, a weak pump, or something else. The car has been sitting for about 7 years, but it has always done this since I've owned it.
If this is common, I'll put an electric pump back near the tank as a priming pump or something. Otherwise, if folks think a rebuild of the stock pump is in order, I'll do that (where do you get the parts?).
Thoughts? Ideas? Recommendations?
