Can anyone suggest good air shocks to install on my 62 GT? It has all new springs but because the rims and tires do not have the ideal offset I get a bit of tire rubbing when there are passengers in the back. It needs rear shocks anyway so I thought a good set of air shocks would allow me to raise the rear just a bit when carrying passengers. So far I have not been able to find anyone who has a a listing for a 62 GT, here in Canada at least, so if anyone has a product number or proper dimensions I would really appreciate it. BTW the previous owner's mechanic told me the car now has a flanged rear axle vs the original tapered so I don't know if that would make a difference re: the shocks? I found it curious that they put new rear springs on the car but the shocks are much older looking. Wonder if they had problems finding shocks that fit? Hope not! Thanks......
Air Shocks for 62 GT
Here is the cross reference chart the Nate Nagel put together some time ago. No air shocks are listed but it would give you some brand name part numbers to cross to...
http://www.northstarwheel.com/Resources/interchange.pdf
Just a caution. With regular shocks there is little to no load on the shock mounts. With air shocks, you are actually supporting the car from the shock mounts. Make sure your upper shock mount has not deteriorated or it will rip out.
Another idea is to trade in your wheels and tires for ones that fit if you like the current stance of the car.Dick Steinkamp
Bellingham, WA
Originally posted by Dick Steinkamp View PostHere is the cross reference chart the Nate Nagel put together some time ago. No air shocks are listed but it would give you some brand name part numbers to cross to...
Wow, that chart is fantastic, thank you. I have read about the concerns with using air shocks and I honestly would prefer not to but I do like the stance of the car and I like the wheels as they are hard to find spokes that I think look pretty good. The rear springs are new so they are not weak and I would likely only "pump" up the shocks when carrying passengers. When the tires rub it is just ever so slightly so I don't think it would need to be raised very much. I guess the other option would be to add a leaf but then the car would sit too high, I think anyway. The upper mounts are in good condition but I certainly wouldn't want to do any damage and they do look to be a little light I will concede! You can see in the photos of my GT that the wheel wells are definitely full! Thanks again for your help!
- - - Updated - - -
Originally posted by Alan View PostKato, The stock 62 GT rear springs had a much greater true arch for some reason. Perhaps the new springs do not have the same true arch. It looks a little low in the rear, from your pics.Dick Steinkamp
Bellingham, WA
Originally posted by Dick Steinkamp View PostI'd say the same. It's 1" or so lower than stock in the rear.Last edited by Kato; 11-23-2015, 05:35 AM.
Try adding a leaf just under the main leaf. I have used main leafs and cut off the eyes. It gives a full spring to work without making a harsh ride.
I learned this trick years ago with a Lincoln that leaned to the drivers side. The spring company added one long leaf to the drivers side spring. It sat level and the ride didn't change.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
Originally posted by thunderations View PostTry adding a leaf just under the main leaf. I have used main leafs and cut off the eyes. It gives a full spring to work without making a harsh ride.
Originally posted by Kato View PostIs that a type of shock?I'd rather be driving my Studebaker!
Originally posted by wlfrench View Post
