63 R2 Hawk, hydrovac, front discs, reservoir on firewall, master under floor: what is the proper setting of the master cylinder push rod? Thanks
Master cylinder push rod adjustment
The actuator rod under the floor only needs to be a tad loose when the pedal is full up, maybe 1/16". You can pull the rubber dust boot off and see the piston move when the pedal is pressed. After the pedal is full up, as long as the MC piston returns to a full stop and the actuator rod is loose, then you're fine.64 GT Hawk (K7)
1970 Avanti (R3)
On my '41 service manual it says 1/4" to 3/8" of pedal travel "before the power stroke starts" I used to think that meant before the piston moves but now I suspect it means before the M/C starts developing pressure.
Originally posted by nvonada View Post1/4" to 3/8" of pedal travel64 GT Hawk (K7)
1970 Avanti (R3)
