I have a 1949 Champion in pretty nice shape but the engine is seized, tried for 6 months to get it loose with no luck. Recently got a Studey 2 ton truck with a nice running V8. Wondering if the V8 will fit to the Champions 3 speed w/overdrive. Anybody tried this before?
Has anyone put a Stude V8 in a 49 Champion before?
You might be able to cram a V8 in there; not sure if the sump will clear the Planar suspension. But the T96 transmission will not hold up to the torque of the V8, and there is no ready way to mate the two up, anyway. V8 swaps into pre-'51 cars are pretty scarce. Best one I know of is Frank Van Doorn's '41.Gord Richmond, within Weasel range of the Alberta Badlands
Normally it is not a recommended thing to put a V8 in a pre '51 that was not built to handle it.
The truck Clutch Housing will be way wrong for a Car, and you will need a V8 Trans. like a Borg Warner T-86 Overdrive or a H.D. T-85 and the proper Car Clutch Housing dial indicated to the centerline of the Crankshaft.StudeRich
There isn't a lot of room under the Champion hood. Couldn't imagine a v8 under the hood of the 47 Champion I owned. Also as mentioned before the Planar suspension would be an obstacle on lower side.
Trade the V8 for a nice running six.sigpic1957 Packard Clipper Country Sedan
Lt. Col. Jimmy Doolittle
I think you'll find that firewall modification will be necessary as it was in my '41. I had to modify the firewall to give me about 6 inches more room.
Originally posted by gordr View PostYou might be able to cram a V8 in there; not sure if the sump will clear the Planar suspension. But the T96 transmission will not hold up to the torque of the V8, and there is no ready way to mate the two up, anyway. V8 swaps into pre-'51 cars are pretty scarce. Best one I know of is Frank Van Doorn's '41.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
Originally posted by 41 Frank View PostI think you'll find that firewall modification will be necessary as it was in my '41. I had to modify the firewall to give me about 6 inches more room.1963 Champ "Stu Bludebaker"- sometimes driver
1957 Silver Hawk "Josie"- picking up the pieces after an unreliable body man let it rot for 11 years from an almost driver to a basket case
1951 Land Cruiser "Bunnie Ketcher" only 47M miles!
1951 Commander Starlight "Dale"- basket case
1947 Champion "Sally"- basket case
1941 Commander Land Cruiser "Ursula"- basket case
Do you have the head off? I bought a 1950 Champion about 30 years ago that was also stuck. After soaking for a couple years by me and the seller I finally removed the head. The cylinders all looked perfect, and the only rust was a very small amount of light surface rust on the cylinder that had an open exhaust valve. I still haven't got back on it, but it was sure hard to believe the engine was stuck by the looks of the cylinders.
To unstick Model A engines I made up a tool that bolts in place of the starter. It's a starter end plate with part of the ear broken off one of the three mounting holes, then I used the pinion from a broken Bendix. I welded the pinion to a 5/8" bolt, so I can use a large wrench on the hex head and put a lot of torque to the flywheel ring gear. I've only used it twice so far, but it got the job done.
Six cylinder Champion engines shouldn't be to hard to find, if your's is too far gone. I've picked up two 1951 engines from guys hot rodding the cars.
It IS a 1941 Champion Club Sedan Doug.
Originally posted by DougHolverson View PostWas your '41 a Champion, Commander, or President?Frank van Doorn
Omaha, Ne.
Oil pan mods are not impossible. Perhaps that V8 could find a home under that hood? I would start with stripping out the engine and trans out of that 49 and start taking some measurements. Find out where the motor mounts are going to have to be and reverse engineer it from there. I think if you keep the rear of the V8 very near the firewall, you may see enough space up front to make the needed changes. Now you have to ask yourself if you're OK with using a torch and sawzall on that car? You may need to.sals54
I have heard of different ways to modify the firewall to accommodate a V8 engine, Studebaker or any others. The favorite seems to be the use of a wheel barrow cut to fit and welded in place. The ones I've seen done almost look like they belong there.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
Originally posted by sals54 View PostOil pan mods are not impossible. Perhaps that V8 could find a home under that hood? I would start with stripping out the engine and trans out of that 49 and start taking some measurements. Find out where the motor mounts are going to have to be and reverse engineer it from there. I think if you keep the rear of the V8 very near the firewall, you may see enough space up front to make the needed changes. Now you have to ask yourself if you're OK with using a torch and sawzall on that car? You may need to.
Of course, any suggestion I have must be taken with a grain of salt. It has been over four decades since I have built a modified vehicle. I'm kinda set in my ways, comfortable with "old cast iron technology," and old enough to realize the value "others" should put on my opinions. (Meaning, talk is cheap.) There are lighter, more dependable, more efficient power to weight ratio, engines available. From four to eight cylinder engines, there are many "out there."
It would be interesting to see someone research the subject to the point of mating our old Stude bodies to a modern (say no older than ten year old) complete chassis. I believe there is something akin to this being done in this thread... http://forum.studebakerdriversclub.c...highlight=1948
I have not followed this very technical build close enough to understand all it's nuances. I'm not familiar with the particular Nissan chassis/drive train.Now that I'm retired, I no longer have the ability expand my income for such a project, nor the energy, and probably not enough life left in this old body.
My main point is to not limit your options to "old cast iron." I'm considering a "cast iron" project myself, 'cause that's where I'm most comfortable. Anyway, what ever you do, I hope it works out to a very enjoyable experience.John Clary
Thanks for all the input. I went out and did some quick measuring today and found the V8 is too long for the stock compartment and the oil pan would definitely hit the steering. So that kills that idea. I do know of another running 6 cylinder, just takes money. Already have 5 other projects with major modifications, just want one simple one for a change. Thanks everyone.
Originally posted by thunderations View PostI have heard of different ways to modify the firewall to accommodate a V8 engine, Studebaker or any others. The favorite seems to be the use of a wheel barrow cut to fit and welded in place. The ones I've seen done almost look like they belong there.
Even if this were possible, would the front suspension take the additional weight of a V8? If its weight flattened the Planar front spring any, your front alignment would be badly out of adjustment. I like the idea of swapping/selling the V8, and getting an original-type 6 --- then you just drop it in and don't worry about modifying the car. But then, I'm a "purist" as far as my '47 Champion goes.Last edited by Greenstude; 10-21-2015, 07:31 AM.Bill Jarvis
