So Im in the process of converting from 6 volt to 12 volt and earlier someone brought up the point that I may need to get a new overdrive relay and solenoid for the 12 volts Im going to be running. Im a little embarrassed to ask but figure better now then realize I do or dont have what I need so here it goes.....How can I tell If I have overdrive or not??? I purchased the car not running and this is my first attempt at rebuilding a car. If I do need to get a new relay and solenoid, where should I begin my search and is it even necessary to run overdrive, Its just gonna be a cruiser for me. I have a 1949 champion 4 door sedan.
overdrive
Overdrive is a much underrated blessing. Passing gear, (kick out of OD at 45 and go zooom) is great, loafing along at 70 with the engine just ticking over is pretty nice, too. These are things the people with 5 speed transmissions don't get, at least not without moving a gear shift.
12 Volt overdrive down NOT use a relay, it takes power straight from the battery, (fused, of course).
How can I tell If I have overdrive or not??? Look at the transmission. does it appear to have a front section and a rear section? If so, it's OD. Does it have a beer can sized sheet metal thing sticking out from the joint between the two sections, then it's an OD. If both of these answers are No, then it's just a regular 3 spd transmission.
[img=left]http://www.alink.com/personal/tbredehoft/Bothcars3.jpg[/img=left]
Tom Bredehoft
'53 Commander Coupe
'55 President State Sedan Project
'60 Lark VI (Now on the market)
'05 Legacy Ltd Wagon
All Indiana built cars
A '49 Champion with overdrive would have a relay screwed to the firewall, attached by wires to a kickdown switch on the throttle bellcrank behind the carb; wires also running to the solenoid on the trans overdrive unit (the beer can Tom refers to). It would also have a lockout cable to the trans from a T-handle (marked OD) under the dash left side of steering column.
For whatever reason, much of this could have been removed or the trans may have been from a donor. The beer can (solenoid) would not have been removed or the trans lube would leak out.
For local cruising you don't need overdrive. If you plan on doing any long distance cruising with that little flathead, OD is the way to go.Brad Johnson,
'56 Sky Hawk in process
Rockne, not sure where the kickdown switch would be. On 12 V systems it's where you said. On my 53, the kickdown is inside the firewall with a plunger going through so tracing the wires is a bear. But there should be a relay on the firewall, above the steering column.
Tom Bredehoft
'53 Commander Coupe
Tom Bredehoft
'53 Commander Coupe
The 12 volt systems in '56 and '57 used O/D relays. IIRC, in '58 the system was changed to eliminate the O/D relay.
Paul
Visit The Studebaker Skytop Registry website at: http://hometown.aol.com/r1skytop/myhomepage/index.htmlPaul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
The OD relay is on the firewall to the left of the voltage regulator. It has a fuse stuck onto it. As mentioned earlier, if you don't have a T handle under the dash that says "OD" you probably don't have overdrive.
1950 Champion
Holdrege NEJohn
1950 Champion
W-3 4 Dr. Sedan
Holdrege NE
It just goes to remind me that I don't know it all. One more time.
Thanks, Paul.
Tom Bredehoft
'53 Commander Coupe
