Have a 52 commander that the front coil springs are going bad on. I have new 53 and 62 V8 coil springs here. Will they interchange?
52 commander coil spring question
Check the wire diameter. There are heavy duty springs, 6 cylinder springs and V8 springs. Also, I would only replace as a pair. Define "new". New for the 52, or brand new, never used. If the replacement springs are used, check them for height, side by side. Use the taller of the two on the passenger side. The shorter of the two probably has wear and tear of a lot of driver side use. Then when you sit in the car you'll be leveled out.sals54
