As one famous person once said, "Let me make this perfectly clear," I am not planning to enter my 1950 in any car shows beyond local festivals and the like. Therefore, I do not plan to sandblast the frame and everything else that the local people tell me I need to do to restore the car. I am using metal to replace some areas and in some areas I am not taking any bondo out if it appears to be in good shape after 14 years(no bubbles etc.). There are very few areas where the metal has split an inch or two in bends etc. and these will be repaired with metal/welding. The interior will be redone from floor covering to headliner. After treating all the fenders etc. I will be putting the car back together before having a bodyshop do the final sanding and painting on the exposed part of the car. I intend to keep the car original as much as finances and time will allow. But, even with all the new rubber and glass etc, I do not expect to have a show car. I plan to keep the car inside when it is finished and drive it on a regular basis unless the weather is wet.
Now, after saying all that, my question is this, has anyone had any experience using the Klean-Strip Rust Converter under the fenders, on the frame, bottom of floorboard, headlight buckets and other out of sight rusty areas. The car is very clean in these areas but with a surface rust on everythging-no flakes etc.
What I am planning to do:
1. wirebrush the rust off pretty good
2. spray the rust converter on it the TWO TIMES that it suggests on the can
3. Then brush away any loose flakes that may show up and treat those areas again
4. Apply undercoating to the underside of the fenders and the floor board
5. Paint everything else underneath-the entire frame, driveshaft, springs, gastank neck and other such parts.
Would it be better to simply spray all the under parts(after rust treatment) with a good black paint and forget the undercoating? By spray I am talking about cans of spray paint like Rustolium.
An automotive paint supply tech told me that since I was not wanting to spend a lot of money that I should go with-I think he said acrylic-enamel for the outside of the car. Does this sound right. He said that it would not need a clearcoat. The car will be painted red again as close as possible to the red it was when I had it painted in the late 80's (It was black when I bought it in 74), unless my wife changes my mind! When I figure out how to put a picture of it with my signature you can see what it looked like 14 years ago when I sold it.
What do you think guys and gals? Talk to me in simple non-technical terms.
Thanks for your input.
Jim
1950 2 timer
Orleans, Indiana
Jim
1950 2 timer
Orleans, Indiana
