I looked at an oil pan today that the seller says is early 50's. The sump is in the rear, and the rear opening is 4 1/2" from edge to edge. The front opening is 6 3/4" to the edges. Does anyone know for sure if this is the correct pan for a 1952 Champion? Thanks, Tom
Oil Pan End Opening Size for a 1952 Champion?
Pictures or part number would help; depth and length of sump? All others are speculation.Brad Johnson,
'56 Sky Hawk in process
Tom, I have a n.o.s. oil pan that's for 1955 - 1964 Champion six. and I don't know what would be different on pre 55 on up ? or if any actual variance, is it nothing to worry about.
Originally posted by TWChamp View PostI looked at an oil pan today that the seller says is early 50's. The sump is in the rear, and the rear opening is 4 1/2" from edge to edge. The front opening is 6 3/4" to the edges. Does anyone know for sure if this is the correct pan for a 1952 Champion? Thanks, TomJoseph R. Zeiger
Sedan or C/K would be different. '51-'52 Champion part number 529264. '53-'54 Champion part number 531917. '51-'52 Commander part number 527145. '53-'54 will depend on body model.
Just saying...!Brad Johnson,
Brad, I wondered also "but" 55 - 64 takes in Larks/Lark types and I'll have to get out in the garage and check the # could it start with 15 ?
Originally posted by rockne10 View PostSedan or C/K would be different. '51-'52 Champion part number 529264. '53-'54 Champion part number 531917. '51-'52 Commander part number 527145. '53-'54 will depend on body model.
Just saying...!Joseph R. Zeiger
Originally posted by 63t-cab View Post... "but" 55 - 64 takes in Larks/Lark types ...Brad Johnson,
