I have two small jobs which need to be done on my Sky Hawk. The hand brake control needs to be reassembled and I want to put a valve in the heater hose line as the switch is kaput and evidently costly to repair. I will pay for this service. My local shop here in the Hamptons will charge me up the ying and down the yang, and I'd much rather give the money to a fellow forum member who knows what he's doing. Parts can be obtained if necessary.
Mechanic needed at Warwick
Originally posted by plee4139 View PostI have two small jobs which need to be done on my Sky Hawk. The hand brake control needs to be reassembled and I want to put a valve in the heater hose line as the switch is kaput and evidently costly to repair. I will pay for this service. My local shop here in the Hamptons will charge me up the ying and down the yang, and I'd much rather give the money to a fellow forum member who knows what he's doing. Parts can be obtained if necessary.peter lee
Peter, the Warwick meet is not until June, 2016 - next year. There won't be anyone going to Warwick, RI until then.
Good luck with your ying and your yang!Gary Ash
Dartmouth, Mass.
’41 Commander Land Cruiser
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
Most SDC people are busy from morning to night on Convention week. I am always willing to help someone with an unexpected breakdown and probably many others are also. I certainly would not do any repairs that should have been done before the person left for the Convention. In Gettysburg, there was a staffed and equipped building set up for emergency repairs. Some people tried to get routine work done. I believe that they were turned away as that was not the intent of the service.Gary L.
Be sure you get the PROPER Parts at a Studebaker Vendor at: http://studebakervendors.com to give to the Mechanic, to save you a lot of time, trouble and Money! The standard Shop procedure is to DOUBLE any Parts Prices for parts they purchase.
The proper replacement WATER Valve (if that is what you mean by kaput switch) is available as 800783, the Heat Control Lever will work backwards but the Ball Valve is a very long lasting high quality unit.
There is a special Spring and Cog in most Hand Brake assemblies that centers and prevents unneeded turning of the handle SHAFT, another Studebaker Dealer only Part.
Why not search out a Classic Car Shop Out of "the Hamptons"?Last edited by StudeRich; 08-11-2015, 12:21 PM.StudeRich
Originally posted by jbjr View PostI drove the Island for years and seen plenty of stude's out there. There are a lot of sdc members out in long island why not just contact one of them and see if they can give you a hand?
You keep talking about "...here in the Hamptons..." Your address shows up as East Northport. Which is it? East Northport is only about half way from NYC to the Hamptons.Gary L.
Matt, you wouldn't believe some of the requests I get from people in the hopes of saving a little money. It is usually something I can do in a minute and don't charge for, but by the time I explain that and educate them why they should just do it right, I have to start charging them and my litigation rate is $400 an hour. "Now you're going on the clock!"Dave Warren (Perry Mason by day, Perry Como by night)
