Does the dash unbolt so I can get to the instruments? I have all new Sun Pro instruments to install, as well as a Burlwood vinyl to re-do the instrument plate and the console and glove box. I cannot stand on my head and replace the Instruments in that limited space.
71 Avanti dash
If you remove the wiring, speedo cable, oil pressure tube, etc. and undo the steering column support, lower the column to the seat base. You also have to undo the underdash console sides... There are the dash brace bolts (which are fairly easy), then at the base of the windshield are 4 smaller studs with washers and nuts. The windshield fasteners are the most difficult part, then the dash lifts up a tad and comes toward the seat..... I may have missed something small, but that's the crux of it..64 GT Hawk (K7)
1970 Avanti (R3)
I pulled all my gauges out of the 83 by using a combination of reaching underneath, through the top of the dash where the radio grill would be and removing the end cap from the dash and cutting an opening that would be covered when you put the cap back on.
As Ed said, nasty job but I got it done. I'm not sure what's behind the end cap on the 71 but you should be able to look up and see if there's an advantage to getting in from the end.
Bob
Originally posted by sweetolbob View Postremoving the end cap from the dash and cutting an opening....
Bob64 GT Hawk (K7)
1970 Avanti (R3)
Having hands the size of a five year old child is a great help...so is having long, slender fingers and a skinny arm. A normal size adult will have problems with clearance.
An Avanti II is usually more difficult to remove gauges than a Studebaker built Avanti...there's more under the drivers side of the dash...hazard flashers unit and wiring...electric trunk release and wiring if so equipped...rear defogger switch and wiring...more than Studebaker installed that you have to squeeze your hand through and around.Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
Originally posted by 64V-K7 View PostIf you remove the wiring, speedo cable, oil pressure tube, etc. and undo the steering column support, lower the column to the seat base. You also have to undo the underdash console sides... There are the dash brace bolts (which are fairly easy), then at the base of the windshield are 4 smaller studs with washers and nuts. The windshield fasteners are the most difficult part, then the dash lifts up a tad and comes toward the seat..... I may have missed something small, but that's the crux of it..Bez Auto Alchemy
