Today I decided to strip down and clean up the block from that '63 Lark VI that I'm parting out. Cleaned most of the crud off the outside with a putty knife, then figured I'd run the hone in the cylinders to see how they'd clean up. #4 had been the worst-looking, so I started with it. Quite a lot of pitting near the bottom, mostly below the ring travel area, where water sat on top of the broken piston. The rest of it cleaned up OK, with the exception of some shallow scratches. No ridge to speak of. If the rest of the cylinders were OK, this one, if fitted with a new piston, might burn some oil, but the engine would run, I think.
Ran the hone in #3, and uh-oh, cracks. At least one, probably two, slightly curved, and slightly off-axis to piston motion, so they can't be scratches. I can catch a fingernail in one, after having run the hone. So this block is toast, unless it gets sleeved, and that's scarcely worth doing, seeing as there are uncracked blocks to be had. I won't toss it, because who knows, maybe somebody will want an OHV block to sleeve way down to some smaller displacement for racing purposes.
I removed the camshaft and cam bearings, which all look good, as do the main bearings, which all were in the right way, so no clue why the two middle rod bearings went. No serial number on this block, as it was a service replacement engine.
Guess I will clean up the remaining parts, and store them away.
