View Full Version : Fuel System: Thin/Thick Gaskets.
Lou Van Anne
05-04-2015, 06:27 PM
I just removed the carburetor from my R2 Hawk. The gasket appeared to be about 1/4" thick. I ordered a gasket from Chuck Collins that appears to be correct but is much thinner. Can anyone explain why the difference?
SN-60
05-04-2015, 06:50 PM
Stude Factory carb gaskets on the Avanti engines were about 1/4" thick for insulation purposes....The normal 'thin' AFB gaskets are usually installed in a stack of three, which seems to accomplish the same thing.
41 Frank
05-04-2015, 08:50 PM
I just picked up two of those thick, as original, gaskets from Jon Meyer at the South Bend swap Lou. So I know he has the right ones.
Mike Van Veghten
05-05-2015, 07:27 AM
Either will work fine.
Thicker gaskets allow a smaller amount of of heat transfer from the manifold to the carburetor, which is a good thing.
DO NOT stack three or four thin gaskets to make a thick version (without steel seperator plates !). You'll end up snapping a corner off of the carburetor..!
