View Full Version : Body: H E L P What years are these 3 studes
bradnree
04-30-2015, 12:45 PM
3 Stude trucks:
R11 7751 2R11 22
6E40 155 5G3PS E40 4556
R6 10282 2R6 12
Years please
Thanks
Commander Eddie
04-30-2015, 03:43 PM
6E40 would be a 1961.
04-30-2015, 03:44 PM
3 Stude trucks:
R11 7751 2R11 22
R6 10282 2R6 12 2 R6
Years please Thanks
R11 7751 2R11 22 A 1953 3/4 Ton with a 245 Big Six Engine and 122" W/B Long Bed (1949 to 1953 "R" Series all the same).
6E40 155 5G3PS E40 4556 6E = 1961, 40 = 2 Ton, or larger Dual Wheel, V8, 155 Inch W/B
-5G3PS = Nothing, (maybe transcribed wrong, or Codes for Brakes, Axle, Springs etc.)
R6 10282 2R6 12 2 R6 = A 1953 1/2 Ton with a 245 Engine and 112" W/B Short Bed (1949 to 1953 "R" Series all the same).
UPDATE: Serial numbers in Maroon.
bradnree
04-30-2015, 04:39 PM
what numbers above confirm years of each truck
8E45E
04-30-2015, 05:00 PM
Got any photos of them?
04-30-2015, 05:05 PM
I fixed my Post for you, to indicate the actual Serial Numbers which I looked up in my Chassis Parts Catalog attachment that breaks out the Years of '49-'53 "R" Series trucks, the '61 is a no brainer, all 6E's are '61.
Dwain G.
04-30-2015, 06:43 PM
Here is a breakdown of 5G3PS on the 6E40.
5= 5,000 lb. rated front axle
G3= 15,000 lb. rated rear axle with two speed rear end
P= rear axle ratios of 6.61 and 9.09 (high and low)
S= standard duty brakes
bradnree
04-30-2015, 07:43 PM
Which numbers designate 1953 in the R11 numbers
Which numbers designate 1953 in the R6 numbers
05-01-2015, 01:24 AM
Did you Read Post #6 and re-read the updated Post #3? I am done, I can't make it any clearer.
bradnree
05-01-2015, 09:19 AM
Thank you for your help. I need it correct for a new Kansas title for each truck.
7751=1953
4556=1961
10282=1953
rkapteyn
05-01-2015, 10:29 AM
You must be from a younger generation.
Studebaker used serial numbers and modern cars ,the ones the title bureaus are used to, use VIN numbers.
Studebaker serial numbers are a range of numbers for each year of production.
The is no other identification of the year built else than the range of serial numbers.
Find an old geezer (like me) at your state's tittle bureau that still remembers how things were done in 1953.
Robert Kapteyn
bradnree
05-01-2015, 11:23 AM
Robert Kapteyn
Generation "1942"
I see that there is no way to accurately determine the year of Manufacture.
THANKS to all for your help !!!
brad
05-01-2015, 11:43 AM
Generation "1942"
THANKS to all for your help !!!brad
I am sorry Brad that you still don't get it, I thought for a moment that you did in Post #10. :ohmy:
The Starting Serial Number for each year is a KNOWN factor per the Parts Catalog, when the vehicle in question's Serial Number EXCEEDS the Starting number for a given YEAR, but is LOWER than the Preceding Year's Starting Serial Number within each Weight of Truck (Model Number) the Year Model IS determined/Verified.
So your '49-'53 "R" Series Trucks ARE 1953, because I checked.
Serial Number: R6 10282, Model Number: 2R6 12 (1953)
Serial Number: R11 7751, Model Number: 2R11 22 (1953)
Serial Number: E40 4556, Year Code & Model Number: 6E40 155, Equipment Codes: 5G3PS (Used for Heavy Trucks) (1961)
bradnree
05-01-2015, 12:35 PM
Thanks got it.........brad
bradnree
05-01-2015, 12:47 PM
I need the title of your book(s) so that I can have that info at hand in the future.
brad
Skip Lackie
05-01-2015, 01:02 PM
brad
The factory parts books include starting serial numbers for (nearly) all model years. Model years for some, like the 1949-53 2R-series trucks, have had to inferred or determined by consulting other sources, like factory service letters or annual truck data books.
bradnree
05-02-2015, 11:11 AM
http://www.studegarage.com/REFDATA/2R_sernum.htm
I found this help, on line in a yahoo search.
brad
bradnree
05-02-2015, 11:14 AM
I'll see how to load pics on this site.
brad
bradnree
05-02-2015, 11:18 AM
thanks
brad
- - - Updated - - -
thanks
brad
bradnree
05-05-2015, 09:56 AM
http://www.studegarage.com/refdata/2r_sernum.htm
i found this help, on line in a yahoo search.
Brad
thanks skip lackie
bradnree
05-17-2015, 07:51 AM
See three ebay listings. They are now for sale.
brad
