I am reaching out to see if anyone could tell me the stock diameter and length of the coil springs for a 56 Golden Hawk. I have my suspicions that mine were changed or cut at sometime by a former owner. Any info would be appreciated.
coil springs
IIRC they are about 14" tall, free standing, but yours are probably still installed. If it has the standard 56J springs (part #526124), it will probably sit low; no need to cut the coils. If it has the HD springs (526125) it will sit up nice and healthy, about 24-25" measured at the lower lip of the front fender, dissecting the axle. . For repro of either spring, google a place in Kansas called, "Coil Spring Specialties".
If you have your springs out, which you need to do to measure the unsprung height, you will be able to know exactly which springs you have because the Part Numbers Joe gave you should be stamped right on the Inside of the bottom Coil.
I have seen some on the Outside and also some on both ends.Last edited by StudeRich; 04-24-2015, 11:39 AM.StudeRich
