I just purchased a 1950 Champion. It currently is painted a flat sky blue. The interior is a dark tan or perhaps a bronz but I want to determine the vehicle's original exterior color. If it helps, the vin is G572613. Please respond to wiltoole@aol.com Thank you
Exterior Color - 1950 Champion
If you're lucky, the color code is still stuck to the bottom of the glove box. If not, contact the Studebaker museum and get a copy of the production order for YOUR car. That'll reveal paint codes and other info regarding when your particular Stude was built.
Miscreant adrift in
the BerStuda Triangle
It's awfully hard to do a complete repaint without leaving a trace of the original color somewhere; under a weatherstrip or sillplate or on the underside of a floorpan above the trans. As Mr. Biggs indicated, if the tag isn't attached to the glovebox, and you can find no telltale color anywhere, the repainter did a thorough job and you will only find the original color on the build sheet from the National Museum.Brad Johnson,
'56 Sky Hawk in process
In all honesty, it's highly possible that the "flat blue" the car wears presently is the original paint that's gone dead over 57 years![xx(] They DID have a couple of shades of blue that year.
Miscreant adrift in
