Hi all,
First, let me thank you all for the advice you have given me regarding my 1965 Commander in the past on here. When the car is done, I'll post pics and share the story of the car.
Anyhow, I am getting close to having the floors done and my next step is pulling the engine and trans out of the car to paint it. It has the original 283 in it. I'd like some advice on colors, the best paint to use, and most importantly how to prep it.
I'd like to use Semi-gloss black on the block, oil pan, transmission housing, etc. I have the yellow paint from SI for the valve covers. I am thinking of using Eastwood's underhood semi gloss for the pulleys and upper/lower radiator tanks (not re-painting the fins).
I'd like to find the best and most permanent paint in semi-gloss black. I was looking at POR 15 products, but the only thing in semi-gloss is their chassis black topcoat, which can withstand up to 300 degrees, so that may be okay for this engine. In reading old posts on this topic, it seams that the exhaust cross-overs on the stude V8s get too hot for normal engine paint.
So, I'd like your advice on how to to it right and what paint to use. I'm planning on using a paint gun to apply to the engine, rather than spray bombs, unless otherwise advised.
Thanks again for all your help in restoring my first car.
Nate
Nate
