1962 Lark 170 3 speed...Anybody got a set of V8 Mounts for me??
Originally posted by Mike Van Veghten View PostHit up someone you need to get to know...Studebaker International.
They have "motor mounts" (both the steel/iron part and the rubber). They may even have the trans. crossmember. Seems I saw some somewhere.
Len
The '51-'52 Engine Mount Brackets have large center holes for the through bolt and Upper and Lower Ford Type Engine Mounts used on early V8's, unless you use the (4) '51-'52 Engine Mounts, anti-crush Sleeve, and LONG through Bolt you cannot use '51-'52 Engine Mount Brackets, although it is a good "High Performance Driver" update Mod.
The 1953 to '64 Sedan, Wagon and Lark V8 Brackets, are the bolt on "Normal" 6 to 8 Cyl. Upgrade Parts.
You can start collecting the Clutch Housing, Transmission, Driveshaft, Rear End, Flywheel, Clutch, Clutch & Trans. Linkages, Brakes and Front Coil Springs for the upgrade now also, if that is your plan. The 259 Engines are easy to find, and the 289's a bit harder, but out there.
That is a sharp looking '62 2 Door, I can hear it crying out: "289, 289, 289"!
Just my opinion, it's YOUR Car after all, but the FIRST thing I would do, is ditch those extra 2 Outboard Front bumper guards that almost cut the Headlights.
Some people here would remove all 4, but I like the look of the properly mounted 2 Guards.
Parts are available at: http://studebakervendors.comLast edited by StudeRich; 04-06-2015, 12:15 PM.StudeRich
Three Days later, Now it is on the BLOCK? You never mentioned that possibility.
I guess the 259 or small block swap isn't happening.
Sorry to see you go, but a mention here might have sold it for free.StudeRich
It will not sell, just throwing it out there...also have 2 Econolines on there, Told mama I would try to sell a few....not selling any of my 7 Falcons or my 2 AMX's or my 69 Mustang GT FB, or my 56 Chev, 2 door sedan....This the issue I have, I have WAY to many toys....Oh yea....also my 1971 Pinto, 2.3L Turbo-5 speed...lol.....I did sell my Box truck and a Boat....did take the Lark to the 1st cruise in of the year did ok....but screaming for a V8
