Hi guys. Just wondering if anyone knows fer sher if these two tanks are swappable? I don't need a perfect fit, just need it to work. Thanks
Are C/K and 56 Wagon gas tanks interchangeable?
Sal, a sedan or coupe tank would be different than a wagon tank due to the spare tire well. However, the tank from a '63 wagon I had fit right on my '56 wagon. I think one of the holes had to be re-drilled, but other than that, fit right on.Home of the famous Mr. Ed!
Ron Smith
We thought we had a Hawk tank here until we compared the Mounting holes, they did not match to a Wagon tank, and I am not sure but I think the filler pipe was off a bit also, they sure look alike at first glance, but are not. That could work for you with some creative brackets to mount it.
The C & K tank and the wagon tank both fit to a lay down spare tire, the Sedan is the narrower & deeper tank for the stand up spare that will not work.Last edited by StudeRich; 04-03-2015, 11:07 PM.StudeRich
A '63 stationwagon tank however will bolt right up (two of the three holes) and the filler will also line right up. I wouldn't know about any other year though. Still, the '64-66 wagons are almost identical underneath, so would also likely work.Home of the famous Mr. Ed!
Ron Smith
the sending unit is located differently so your acces hole in the trunk floor does not match. cheers jimmijimOriginally posted by studeclunker View PostA '63 stationwagon tank however will bolt right up (two of the three holes) and the filler will also line right up. I wouldn't know about any other year though. Still, the '64-66 wagons are almost identical underneath, so would also likely work.sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
Fuel cells are getting cheeper or you could weld up a tank out of steel plate.If you car is ugly then it better be fast.....
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
63 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MC
45 Agricat
67 Triumph T100
66 Bultaco Matadore
