Just curious , what is that, on the inside of fender , is that hard to remove? Not gonna touch it , but who would think they would build and put something there. My car has two heaters , One the climatizer, and then box under the glove compartment area , . Mike
What part of the heater is at the back / inside of fender ? 55 2 door president
That is the Climatizer System under the floor, Heater Core induction FAN to pull air from the should be open, right fender Air Vent Door and push it to the under the Seat Heater Core.
Three Bolts and Nuts on the Inner Fender under the hood secure it, plus the 4 Inch Duct Hose Clamp.
There is supposed to be also be a Defroster Fan with a water heated Coil on the right Firewall closer to the center.
An aftermarket recirculating Sears, Montgomery Wards, Western Auto, Pep Boys, or J.C. Whitney "Box" Heater must have been added to your Car for Alaska use!
A good condition 5 Ft. Heater Duct Hose from the fender vent & Fan to the Heater core is very necessary to keep Oil vapor, exhaust, dirt etc. out of the system and the Car and get the Heat.StudeRich
So the climatizer isn't hook up ,because the heater hoses are cut , at the body mount ,inside the engine compartment . Also that big hose inside the fender was ripped down ,when I first bought the car ,and was having it service. I wonder should I go to my local welder and see if I can have a decrative door made for the heater under the glove compartment, It has two out of three narrow doors for the heater.
Originally posted by 14x7 View PostJust curious , what is that, on the inside of fender , is that hard to remove? Not gonna touch it , but who would think they would build and put something there. My car has two heaters , One the climatizer, and then box under the glove compartment area , . Mike
EDIT: From your new post, made when I made mine, it sounds like an additional aftermarket heater, without a fresh air feature, was added under the dashboard. Maybe the original heater leaked and rather than repair it, it was just disconnected and this additional heater was installed.Gary L.
Since a "Box Heater" is recirculating and not Fresh Air Forced, I would go the other way, replace all the Studebaker Heater hoses, hose adapter to the Defroster and other deteriorated parts and remove the "box heater".
Actually not a bad picture Kerry, only the '51 is like Night and Day different than the OP's '55 Setup.StudeRich
The heater under the dash works , cause when I was driving it , it was hot in the summer time . So I turned that cable connection to the heater ,and stopped the heat from coming in. The cable pull ,is too stiff , I have to regrease or oil that cable .
Originally posted by 14x7 View PostSo are you telling me that fender door doesn't bring air into the passenger compartment in the summer time. Whats happening with that big hose thats missing ,its not bringing fresh air in ?
The inside door is not opened for Winter, you would be surprised how many New Car owners did not know these two tidbits I have shared, not all Dealers would explain "things"!StudeRich
thanks Rich, i wasn't sure if it was close to a '55 - i was kinda going from your post:
"A good condition 5 Ft. Heater Duct Hose from the fender vent & Fan to the Heater core is very necessary to keep Oil vapor, exhaust, dirt etc. out of the system and the Car and get the Heat."
just tryin' to help.
BTW: other than using the defroster when i got caught in a rainstorm last week, i've only had my climatizer on a couple times this winter - just to circulate the coolant after getting to operating temp...Kerry. SDC Member #A012596W. ENCSDC member.
Kerry, the major difference I noticed right away is that it appears that '47-'52's had that 4 Inch duct Hose going to the inner Fender mounted Heater Fan, whereas the '53-'62 C & K and '53 to early '57 Sedan/Wagons come from the "inside the Fender" Fan like the OP's does. Quite different actually.StudeRich
