I'm in the process of a complete rewire of my 63 Wagonaire with a 259ci engine. Does a ballast resister need to be installed for the points or does the coil already reduce the voltage? It didn't have one on it and ran well without burning the points.
Ballast Resister
Tags: None
To be sure you could take an amp reading. If the points are closed, key on and 12 volts across the coil, it should draw about 4 amps. In other words, the coil would have about 3 ohms across the primary terminals if no external resistor is needed. If the amp draw is about 8 amps, then it needs an external resistor. If the ohms is 1 1/2 then it needs an external resistor to be run on 12 volts.
TWChamp, that's not possible now. The old harness is out and the new one is going in. I was told that the coil could be one that reduces the voltage, is there any way to confirm that while it's off of the car? I was also told some cars used a stainless wire for more resistance but stainless wire was not connected to coil from distributor.Gary
That depends on what kind of a "Harness" you are installing, the original Harness had a Pink Resistance Wire from the ign. Sw. to the Coil, the replacement Harness???
Factory duplicate new Studebaker Vendor replacement, NOS New replacement, aftermarket do it your self kit?StudeRich
Originally posted by StudeRich View PostThat depends on what kind of a "Harness" you are installing, the original Harness had a Pink Resistance Wire from the ign. Sw. to the Coil, the replacement Harness???
Factory duplicate new Studebaker Vendor replacement, NOS New replacement, aftermarket do it your self kit?Gary
The ballast resistor is just one method of reducing the voltage across the points to an acceptable level where the points won't cook and turn blue and fail.
Other methods for reducing that voltage is a resistor wire (which Stude used in some models) and an 'internal resistor' coil.
Quick method to check to see what you have.
Turn your key to 'on'
Check your voltage at the coil .
It should read 7.5 volts.
That would mean you have a resistor of one of these types in your system.
If your voltage reads 12 volts, then you need to add one of the types of resistors to reduce that voltage down from 12 volts.
Note: When you turn your key to 'start' (crank), there is a bypass circuit that allows the full 12 volts to go across the points, but only during cranking.
The 'run' voltage should be close to 7.5 volts.
Knowing what you have now is important, because adding an internal resistor coil to a system that has a resistor wire will cause a low voltage scenario.
(You can usually visually tell an internal resistor setup if there are two wires running to the plus side of the coil).Last edited by DEEPNHOCK; 03-31-2015, 05:41 AM.HTIH (Hope The Info Helps)
Originally posted by DEEPNHOCK View PostThe ballast resistor is just one method of reducing the voltage across the points to an acceptable level where the points won't cook and turn blue and fail.
(You can usually visually tell an internal resistor setup if there are two wires running to the plus side of the coil).Gary
Originally posted by garrilla View PostJeff, is it possible to bench test the coil? The rewire is already in process and I won't be able to test coil online until wiring is complete.
http://tinyurl.com/bench-testing-ignition-coilsHTIH (Hope The Info Helps)
Originally posted by garrilla View PostThanks Jeff, I should have thought of that.
The Internet is an amazing resource... Way smarter than I am...HTIH (Hope The Info Helps)
StudeRich's reply prompted me to check the wire diagram and there is a pink resistance wire from the ignition. So with the new harness I'll have to use a ballast resister. Looks like I'll have to trace which wire pole on the starter solenoid to have a 12V source to bypass ballast for starting, any advice? The starter solenoid has 2 small posts, 1 on the battery side and 1 on the starter side. Does the 1 on the starter side put out 12V when the key is turned to start?Gary
The ignition coil is NOT Stude specific you can swap the coil out if you do not want to run a resistance wire and thay way when you bowtie it you will all ready have a 12 volt lead for the coil.If you car is ugly then it better be fast.....
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
63 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MC
45 Agricat
67 Triumph T100
66 Bultaco Matadore
