I'm upgrading my 64 Champ 8E7 to dual exhausts. I have seen underside pics posted here before of other owners who have done this with the 259, but I can't find them at the moment. If you have pics of this upgrade, or even pics of an original dual exhaust Champ, showing a clear layout of the pipes, I'd love to see them!
Looking for pics of Champ dual tailpipes
Mike, best place is over at the Studebaker Truck Talk, here is a link: http://www.network54.com/Forum/23885
Here is a thread with a couple of pics on a C-cab (basically the same chassis as a Champ):
http://www.network54.com/Forum/23885...alf-ton+C-Cab-
I've got a dual exhaust system from Don Simmons but have not fully installed it yet. It is similar to the pics in the link above, both pipes run parallel down the passenger side.Paul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
I do'nt have any pics to post.but ran duals on my 63 champ V8,these are duals right from the manifolds on back. I do'nt see the need to run both pipes together down the passenger side - but to each their own.Joseph R. Zeiger
I had dual exhaust pipes installed on my 64 Champ with a 289. I had both pipes run down the right side with glass pack mufflers. The left pipe after the muffler crossed over the differential to the left side. It ran that way for the 25 years I owned the truck. Bud
You could ask over to Parks Pipes, they helped me come up with a dual exhaust for my 1965 Wagonaire.
They advertise in Turning Wheels.sigpic1957 Packard Clipper Country Sedan
Lt. Col. Jimmy Doolittle
Originally posted by StudeNewby View Post/Cut/ If you have pics of this upgrade, or even pics of an original dual exhaust Champ, showing a clear layout of the pipes, I'd love to see them!
On one I had done for a Local member on his 259 Powered 1 Ton Stakebed R Series, I had the Muffler Shop run them on the right, and then it works better without having to untangle them, to have the Right Pipe go across the rear after the Diff. to a Left Side exit and I believe all of Don Simmons pipes do that.
This system causes both pipes to be within inches of being equal length, because the LEFT pipe crosses over under the Oil pan and goes out the Right side and the Right Side Pipe crosses over at the rear making them almost even.
Be aware that no Production Truck ever had Dual Exhausts, I can think of two Prototypes that did (Granatelli Champ R2's) but that does not count.Last edited by StudeRich; 03-18-2015, 05:26 PM.StudeRich
like You said,these trucks were not designed with duals in mind.I simply ran My driver side front pipe just under the frame rail and straight down the outside "opposit the gas tank".My father did this to His 63 Champ back in the 70s and so far no worries.really what,s gonna hit that little curve of pipe,that would'nt first hit either axle or spring perches? I think if any one is using the truck hard/extreme I'd suggest installing a scid plate for the oil pan.
Originally posted by StudeRich View PostThe front crossmember is not dipped to allow a Left Exhaust Pipe to pass through without a lot of jogs or low hanging Pipe, this seems to me to be the reason Pipes on both sides at that point are usually never done.
Be aware that no Production Truck ever had Dual Exhausts, I can think of two Prototypes that did (Granatelli Champ R2's) but that does not count.Joseph R. Zeiger
You didn't ask for advice as to whether to do the conversion or not. FWIW, with taking the left side over to the right and back over to the left to exit, there will be no performance gain on a stock street engine.
For the last several V8 trucks I've done, I just used the standard single exhaust, but asked for 2" or 2.25" pipe and a straight-through muffler. Works fine and sounds fine. That's what I use on the Packard V8 in my '55 E12.
Another FWIW, any street dual system should have an H-pipe or X-pipe connecting the two. Without it, there's a possibility of an annoying droning resonance which can make highway travel less fun.
jack vinesPackardV8
My Dad added a Don Simmons dual set up to his '64 Champ. The pipes travel down the right side before the left goes over the driveshaft. Both pipes exit just behind the rear wheels. It's a real nice job. BTW All pipes are 2".
Rob in PA.
Originally posted by PackardV8 View PostYou didn't ask for advice as to whether to do the conversion or not. FWIW, with taking the left side over to the right and back over to the left to exit, there will be no performance gain on a stock street engine.
jack vines
My 1950 Champion was restored 20 years ago and the guy used a turbo muffler. I don't like the extra noise and droning while on the freeway. The first thing I will do this spring is install a stock muffler.
Originally posted by stude1964 View PostMy Dad added a Don Simmons dual set up to his '64 Champ. The pipes travel down the right side before the left goes over the driveshaft. Both pipes exit just behind the rear wheels. It's a real nice job. BTW All pipes are 2".
Rob in PA.
That sounds like what I will be doing, too. You don't happen to have pics of that setup, do you?Mike Davis
1964 Champ 8E7-122 "Stuey"
