I'm doing a brake job and replacing the felt washers on my 1963 Avanti. For installation of the backing plate, etc. I am following what I found on Bob Johnstone's information site dealing with the rear axle (http://www.studebaker-info.org/64v2488/Axle/ax.HTML). The instructions call for gluing a thin paper gasket on the ends of the axle flange and installing the backing plate over that. My car did not have gaskets on the ends of the axle flanges. It seems to me that the thin paper gaskets may upset the end-play in the axles, as they are, in effect, thin shims. The left assembly is complete to the point where I am ready to torque the axle nut. My question is: Do I need to pull that apart and remove the thin paper gasket on the axle flange? Thanks.
Axle flange gasket, yes or no?
Just set the end play when you are finished. The paper is pretty much non compressible, so there is no need to worry about it. But you may have to change the number of shims when you set the end play.
Remember that both rear wheels have to be off the ground when setting end play.Last edited by RadioRoy; 02-27-2015, 06:48 PM.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Originally posted by GinettaG12P View PostThe car is on jack stands, but at the moment, the right hub and backing plate are off. I assume the right backing plate needs to be reinstalled before checking the end play in both axles.
Feel free, however, to use the gaskets where they really belong: One on each side of the reinforcement plate on the outer side of each backing plate.
Larry
I answered my own question. When I got both backing plates on, I checked the end play on the left axle, where I had installed the 1/64" paper gasket on the axle flange, and found 0.016" of play. Aha, I said, the gasket does make a difference. I pulled the backing plate, remove the gasket, and checked the end play, finding 0.015" So I was wrong. The 1/64" gasket does not seem to affect end play. Now to remove an 0.010" shim from the right axle.
Have you consulted the Shop Manual about end play adjustment?
I only mention that because this is not the recommended method. The Axle end play is only measured and adjusted from the right side after buttoning up the Left and bumping the axle to the left.
Left side end play measurement should tell you nothing. Only the Right side matters and gets the shims.StudeRich
The shop manual is a little confusing and rather sparse about end play. It doesn't show paper gaskets, as your reference to Bobs site does.
Button up the left side completely with or without paper gaskets. No shims. Correct torque, complete. You shouldn't need to get into it again.
When you are doing the left side, allow the backing plate to push the bearing race into place.
DO NOT do anything about end play on the left side.
On the right side, button it up completely, with or without paper gaskets and shims. Allow the backing plate to push the bearing race into place.
Bump the right axle shaft to move both axles tight against the left axle race.
End play is the measurement between the right bearing and the right bearing race only. This is why you let the backing plates push the races into place.
THEN check end play on the right side only.
Decide what shims are needed, remove the right backing plate, remove or install shims.
PULL THE BEARING RACE slightly back out of the axle housing,then let the backing plate push the race back in to it's new location.
Button the right side up completely, bump the axle and check end play again.South Lompoc Studebaker
Originally posted by StudeRich View PostHave you consulted the Shop Manual about end play adjustment?
Originally posted by 55 56 PREZ 4D View PostThe shop manual is a little confusing and rather sparse about end play. It doesn't show paper gaskets, as your reference to Bobs site does.
Originally posted by 55 56 PREZ 4D View PostGlue the paper gasket ?
The paper is only there to fill in minor imperfections between the metal parts. Help stop any leaks. Which it does admirable.
Gluing it may be a little overkill. Although it wouldn't hurt.
Originally posted by 55 56 PREZ 4D View PostCheck out the procedure shown on "raylinrestorations.com/Technicalpages/rearaxle/rearaxle.htm"
Sorry, I don't know how to cut and paste the link.
If you google "Dana 44 axle end play measurement" that link will come up.
