I just finished removing 4 kinks from the left side of my 50 Champion front bumper. It is a rechromed bumper with perfect chrome, so I had to be careful to not scratch or crack the chrome. Some pervious owner had hit something enough to push the left end of the bumper back into the front fender and leave a small mark in the fender. The bumper sprung back almost to where it should be, but the flexing left 4 kinks in the top and bottom edges of the bumper.
I slipped a radial tire over the end of the bumper, then parked my Cub Cadet 7 feet in front of the Stude. I blocked the front wheels of the Stude and used a winch between the Cub Cadet and tire hooked over the bumper end. I winched the tire tight to put forward pull on the bumper end, then used a bottle jack and block of wood to push up on the kink on the bottom edge of the bumper. This removed that kink. I then used a small oak board and pipe wrench to bend the other 3 kinks out. After removing the tire, the bumper was in perfect alignment.
Now I need to do the same thing to the right rear bumper, because the guy hit something the same way, and it also flexed enough to leave a small mark in the rear fender. These bumpers really did their job well and had sprung back into shape with only a few small kinks to be removed.
