Hi all, anybody know where I can get a 12v OD solenoid 4 a BW T96?
lookin 4 a 12v OD solenoid T 96
I believe SI has them with core exchange for a couple hundred dollars. Jerry Kurtz usually has tested used ones for half that. I would suspect a variety of our other SDC venders as well.Brad Johnson,
'56 Sky Hawk in process
Should also be noted that, car OR trucks - T-85, T-86, T-89, T-96 - the solenoids will ALL physically interchange. Technically, 12V solenoids from 1956 and '57 would be two-wire units. 1958 thru 1966 would be three-wire units. 6Volt solenoids (from '55 and earlier) will be two-wire units.No deceptive flags to prove I'm patriotic - no biblical BS to impress - just ME and Studebakers - as it should be.
funny, I've been using mine on 12V for about 20 years now... Only thing I did in 12V conversion was new wires (rats ate the old ones), new bulbs, coil ( not needed with a resistor), and just didn't bother using generator/ regulator they're unhooked... I charge it and drive in the daylight.....LOL
I believe the 64-66 solenoids are also two wire, but not interchangeable with the 56-57 solenoids. This later style can be used, but requires a different wiring harness.American iron, real old school
With two tone paint, it sure is cool
Its got 8 cylinders and uses them all
With an overdrive that just won't stall
With a 4 barrel carb and dual exhausts
With 4.23 gears it can really get lost
Its got safety belts and I ain't scared
The brakes are good and the tires are fair.
Tried to sell her, but got no taker
I"ll just keep driving my Studebaker
