...on a 64 GT Hawk where is the fuse located for the instrument switch on the dash board?
Fuse Location?....
I do not believe there is one, it is not needed since the Instrument Lighting works only through the Headlight Switch which is Circuit Breaker protected.StudeRich
AGAIN: The Instrument Light system HAS no fuse, it is not required because Hawks have separate Headlight and Instrument Light Switches and the Instrument Lights are wired THROUGH the Head Light Switch which has it's own Circuit Breaker attached to protect all.
You cannot run Instrument Lights without Headlights, so no problem.
Not like any Lark.
And no it is not on the small Insulator Board where the Turn Signal and Brake Light Fuses are with the Flasher Unit.
The OP's original problem with the Car is not stated. ???StudeRich
I am wondering if the rheostat to dim the dash lights just needs cleaning.
It would help if the OP came back with a better description of his "problem".Gary L.
Thanks guys, instrument light switch must be bad/dirty since instruments don't light along with the headlights. I'm going to remove the switch and see if cleaning will help. Are new ones available? Any know substitutions?Originally posted by StudeRich View PostAGAIN: The Instrument Light system HAS no fuse, it is not required because Hawks have separate Headlight and Instrument Light Switches and the Instrument Lights are wired THROUGH the Head Light Switch which has it's own Circuit Breaker attached to protect all.
Not like any Lark.
The OP's original problem with the Car is not stated. ???Lou Van Anne
62 Champ
64 R2 GT Hawk
79 Avanti II
Does the Hawk have a separate rheostat like the Larks or not? If your headlights and parking lights work but the dash doesn't, as Gary suggested,I would address the rheostat first.Brad Johnson,
'56 Sky Hawk in process
