Twin Traction Dana 44 worth anything?
A year or so ago I sold a guy an open dana 27 from a 66 commander simply because he wanted flanged axels. When he came to pick it up he brought me his old one just to get it out of his way. It is a 44 TT with, I think, 3.54 gears. Matthew has his eye on it for his Daytona.
Neil Thornton
Hazlehurst, GA
'57 Silver Hawk
'56 Sky Hawk
'51 2R16 dump truck
Many others.
Neil Thornton
Neil Thornton
Hazlehurst, GA
'57 Silver Hawk
'56 Sky Hawk
'51 2R16 dump truck
Many others.
Neil Thornton
quote:A year or so ago I sold a guy an open dana 27 from a 66 commander simply because he wanted flanged axels. When he came to pick it up he brought me his old one just to get it out of his way. It is a 44 TT with, I think, 3.54 gears. Matthew has his eye on it for his Daytona.
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
More on the 3.07 TT... After sand blasting the filthy beast I pulled the cover off to inspect the gears. Probably should have inspected first, but I got lucky and found nice looking gears inside. Only the outer edge of a few ring gear teeth show minor corrosion and no other damage is evident. As ugly as the shed was it was still a roof over this rear end. I've found much newer rear ends with much worse gears due to rust. Since this rear end is without brakes I'm only asking $150.
Joshua
Joshua
I sure hope you were careful how you pointed the sandblaster nozzle at this thing! They're not perfectly impervious to penetration by high-pressure blasts![xx(]
Miscreant adrift in
the BerStuda Triangle
Miscreant adrift in
