I have someone that might be interested In my 1946 M16 Steering gearbox. Question is, Does the shaft to steering wheel come loose if the take the top off gearbox? What I an getting at is my steering shaft is cut off at steering wheel. so it would have to be replaced, and it would be cheaper to ship without the steering shaft . Thanks in advance for any info !
Question on M16 Steering Gearbox
If that is a Ross TA-12 box, the worm is an integral part of the steering shaft. To remove it from the box, you need to remove the bearing retainer around the shaft where it exits the box, plus remove the top cover (with adjusting screw) and push up on the sector shaft so the cam follower disengages from the worm. Then you should be able to take the worm out, along with a mess of loose bearing balls. If your buyer just wants the box "for parts" why not just saw the steering shaft off about 4" above the bearing retainer? In order to use the box, the steering shaft would have to be either replaced (best) or welded (iffy).Gord Richmond, within Weasel range of the Alberta Badlands
Originally posted by gordr View PostIf that is a Ross TA-12 box, the worm is an integral part of the steering shaft. To remove it from the box, you need to remove the bearing retainer around the shaft where it exits the box, plus remove the top cover (with adjusting screw) and push up on the sector shaft so the cam follower disengages from the worm. Then you should be able to take the worm out, along with a mess of loose bearing balls. If your buyer just wants the box "for parts" why not just saw the steering shaft off about 4" above the bearing retainer? In order to use the box, the steering shaft would have to be either replaced (best) or welded (iffy).Randy Wilkin
1946 M5 Streetrod
Hillsboro,Ohio 45133
