I have a early '62 289 that I want to up grade to a R-1. How important is it to have a R-1 Vibration damper with R-1 timing marks? Is it possible to use generic 289 and re-mark it?
R-1 Upgrade
Originally posted by Turismo Tom View PostI have a early '62 289 that I want to up grade to a R-1. How important is it to have a R-1 Vibration damper with R-1 timing marks? Is it possible to use generic 289 and re-mark it?
jack vinesPackardV8
Yes, if your main thought is to have actual, usable timing marks on your damper, sure. Pull the existing damper off, mark the degrees (a computer drafting tool really helps here) -15 degrees and every 90 degrees, on your existing plate and use a fine file or a Dremal type tool and cut shallow degree marks, paint them while/silver, put it back together.
Now...you have not only marks for setting usable ignition timing, but you also have marks that make it much easier to set your valve lash (by the firing order)..!
It really is not about the Timing anyway, the improvement is in the BALANCE and dampening of the "Power" strokes of the high lift/overlap Cam Engine as Jack said, at higher RPM's.StudeRich
Considering the balancer is changed to an R1 part what other changes would need to be made, different water pump pulley etc... or is the balancer the only thing? Timing tab as well, or does the cover have to be for R series engines? Having not had any R series engines to play with I have not bothered to study them in depth.
Len.
The inclusion of some still obtainable TEL will ameliorate any possibility of potential detonationOriginally posted by SN-60 View PostAs jack says, the Avanti dampers are for high RPM work. Still, an Avanti damper would be a good addition. I'd give some thought about using the R1 flat top pistons...Gasoline definitely isn't what it used to be!
Do not add leaded gas to any street driven car. It is never required, and is against the law. Some new cars run just fine with 11:1 compression. Many cars have turbo superchargers....they run just fine too! They have electronically controlled ignition timing to get the most out of the available octane available.Bez Auto Alchemy
Originally posted by Skybolt View PostConsidering the balancer is changed to an R1 part what other changes would need to be made, different water pump pulley etc... or is the balancer the only thing? Timing tab as well, or does the cover have to be for R series engines? Having not had any R series engines to play with I have not bothered to study them in depth.
Len.
Allen1964 GT Hawk
PSMCDR 2014
PSMCDR 2013
Victoria, Canada
R1 Harmonic Balancer
Originally posted by candbstudebakers View PostWhat ever you do I have a few if you or any one wants one, part of the racing stash.
All later V8 cranks are the longer snout I think 62 and later, so yours should be good to go as is.Bez Auto Alchemy
