looked at an avanti today with the engine #RH36. this doesn't seem to jibe with what i found in any of the info. available. would like to know what this engine is and where it might have come from. thank you, george perry
avanti engine id
It is a R1 Avanti Engine for a 1964 Avanti, built Aug.6, 1963
To come up with this you have to read way down to this TITLE:
"1964 V8 engine numbering"
OR:
IF it IS a "P" it COULD be a 289 Engine BLOCK built for a 1964 Lark Type or Hawk, built Aug. (H), the 6,th. 1963.
-P H 3 6-
In THAT case what is INSIDE is unknown, 259, 289 R1/R2 Avanti, what?
Interestingly if it IS, it would be almost the SAME story as this one:
rich, i'm sure not in any position to argue with you, and believe me, i'm not, but the way i read the chart, engine numbers before 8/20/63 don't make mention of an rh plus numbers, only r and numbers. numbers starting 8/20/63 were an r, followed by another letter and THREE numbers. the one in question has but two. make any sense? thanks, george perrygfperry
I guess days less than 10 were SUPPOSED to get a 0, as in 06 not 6 just a mistake, BUT since it was built BEFORE 8/20 I have NO idea what happened, it SHOULD have been 26?
The point being, it is for a 1964 Avanti R1.StudeRich
