more good items in this group.
1- is one nice Weiand 2x2 aluminum manifold with some porting and polishing done all time taking effort, this can use either the 3 bolt or the 4 bolt carbs, the hold down marks have been removed from using the early 4" hold downs, $1000.00
2- is also a nice Weiand 2x2 aluminum manifold with some porting and polishing done, this manifold is set up for the 4 bolt pattern carb it also has had the hold down marks cleaned off, $1000.00
3- is also a very nice Weiand 2x2 aluminum manifold also with some porting done also set up to use either 3 or 4 bold carbs, this one has been painted with very high heat paint , also the bolt holes have been re-leaved some to receive the bolt flat. this has been done on all three manifolds. bores are all 1-1/2'
"...$1000.00
4-this the original box one of these manifolds came in and goes with the first one of the manifolds sold.
5-this is an altered R series pan that is set up for racing and holding more oil the deep well has been added along with a longer pick up tube, there is a hole on each side down near the center for oil return, lots of work into it and might be ideal for someone wanting more oil when racing. $125.00
"...$1000.00
