I need some ideas. I get a pop through the carb and a bad hesitation off of idle. When the automatic trans is put in gear it's nearly impossible to get the car to move without popping and stalling. I am missing something here so maybe one of you can help. Here's the history. I am at the completion of a 5 year restoration. It didn't run when I acquired it. I completely rebuilt the engine. .030 oversize, new pistons, bearings and all the rest. The heads are R1 with the bigger valves. It had them on when I got it so I used them. They have been rebuilt with all new valves, guides and hardened seats. I used thick head gaskets. Ignition is a Myers conversion to the Chrysler type electronic ignition, timed at 24* at full advance. Coil, wires and plugs are new. I rebuilt the correct R2 carb with a SI kit. It has an electric fuel pump and a new mechanical pump. When I finished and first started it and noticed this problem I suspected I missed something in the carb so I shipped it off the Holley Custom Shop. It came back looking really good but the problem was still there. I decided to go back in myself and found that the accelerator pump and its shaft seal had not been replaced. I got new ones and put it together thinking I had found the problem. Not so. Looking in the top I can see gas being pumped through the nozzle when opening the throttle. I have tried the pump rod in all 3 holes. I also began to suspect the rebuilt torque convertor as there was no way to get it up to stall speed. I sent it back to the rebuilder, Dacco, and they found it to be fine. Just to be sure they rebuilt a different unit and certified the stall speed at 2100. No change. It is the same with or without the supercharger connected. I am really still suspect of the carburetor but these pressurized units are too hard to find to give up on it. I am an experienced retired professional mechanic but this is my 1st Stude project.
Help!
Dennis
Help!
Dennis
