I went to look at another Avanti (I am starting to feel like the proverbial bridesmaid) and a weird thing happened. Start up went fine (once there was gas in the float bowls) and the car was able to pull forward and back, stop, all that good stuff. Turn the key to shut off and the car continued to run just fine. The tach went to zero and returned to indicate when in the accessory position. All the other items that should work with the ignition shut down with the key in the off position. Pulled the battery cable and the car still ran, didn't quit until the coil cable was pulled from the distributor.
What say you guys?
What say you guys?
