hub puller
That is a great puller, but you can get a front hub puller for modern cars at the FLAPS for a little over $20 that works just great. In fact, many will just loan it to you. That I what I used on my Avantis. If you were doing these on a regular basis, or course, this would one to get. To get them back on, you just insert the keyway correctly, bevel side down and to the front, and just torque them up WITHOUT any grease or other lube.
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
55 Speedster 7160047
55 Speedster 7165279
It is!
Going back together is simple. Back off the shoe adjustment and slip the hub over the tapered axle. Make certain you use no lubricants on the hub and axle! THEY MUST GO TOGETHER DRY !!!
Insert the key, tap it flush, add your washer and nut, then torque 170-200 ft-lb. Re-adjust your brake shoes.Brad Johnson,
'56 Sky Hawk in process
I have seen some really stubborn rear drums where I was glad to have the knock off type as that Snap-on puller is. That puller is probably the best you will find for rear table axles.
I have also had success with other styles.
One similar to this also works well but I recommend finding one made in the USA, some of those cheap ones tend to break when under pressure.
As indicated above, you do not need a puller or any tools to reinstall the drums
Milt
1961 Hawk 4-speed
1967 Avanti
1961 Lark 2 door
1988 Avanti Convertible
Member of SDC since 1973
There's one for sale on the Stude swap board. Ad Number: 13765 - under July
Originally posted by handworn View PostThanks for the advice, everyone. But by the way, what's the difference between front hub pullers and rear hub pullers?Gary L.
If you are talking about the one I posted, not much. On some modern front wheel drive cars, the bearing is pressed into the hub and the hub and bearing assembly is pressed onto the spindle. The FLAPS don't deal with pressed on rear hubs as those haven't been used for over 50 years. Any of the pullers mentions should work for either. However, on 50 year old hubs, the heavier ones may work better. As I said, I used the FLAPS one and was able to pull the hubs on both a 63 and 64 Avanti.78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
After you have the front wheel off, you just remove the dust cap, pull out the cotter pin, and remove the spindle nut. Usually, if you pull lightly on the drum the outer bearing and washer will slide out and can be removed. On some cars the drum can then be pulled off, but if there is a ridge inside the drum you will have to back off the brake shoes to get clearance."In the heart of Arkansas."
"Here is the one that Bob Peterson and myself use at CandB Studebaker's.
Notice the weld , it had to be re-welded because we used it so many times it broke.
We still beat the crap out of it."
That's very much like the one I bought from Chuck Collins. The trick he taught me was to back the center screw off until the flange sits about 1/8" proud of the flange on the axle hub. Put all the lug nuts on and evenly snug them. Then tighten them like you were putting on a wheel. After a very short time - POP - and you have the hub loose from the axle. It has worked that way every time I've used it. Almost too easy. I still have my heavy, unwieldy three-legged puller, but it's in a canvas bag in the back of the shop nowadays.sigpic
JohnP, driving & reviving
60 Lark & 58 Scotsman 4dr
